runs great untill last 5% of throttle then hesitates and backfires
night
My 2002 240 fourwinns hesitates and backfires when i open it all the way up. It's not until the last 5% of thre throttle is pushed foward that this happens. I have installed new plugs, spark plug wires, distributor cap, rotor button and fuel filter. With the tune up it runs slightly better but has the exact same result at the very top end. I have a throttle body on a 5.7 litre engine. I suspect my fuel pump is going bad or possibly a bent cam.
Don S
Re: runs great untill last 5% of throttle then hesitates and backfires
I
Bent cam ????????
I would suspect a fuel delivery problem to your engine before a bad pump. Try these tests first http://forums.iboats.com/showthread.php?t=283269
You should also get your fuel pump pressure at WOT too.
have you checked and replaced the fuel filter lately?
Ayuh,... Sounds like it's goin' Lean to me....
If could be Anything between the tank vent, to the injectors...
Was there any Water in the fuel filter ya took off,..??
