Re: 1965 9.8 Merc overheating
No, I don't believe so the water you saw coming out of the center section was coming out of the exhaust cooling port. This may help wish I could find a picture of the exhaust side of the engine to show you how it works but I guerss I will try to explain it.
First a couple of facts about cooling system of the 10 HP and less engines
1. The telltale is not the cooling water exit, probably 90+% goes out with the exhaust, the water out of the telltale simple lets you know the pump is working.
2. When ever a impeller fails you must find the impeller bits that have broken off, if they are left in the cooling system after the repair, when the engine is started the water flow will push them to a restricted spot in the system and plug it up. There is no way to dislodge them with air as they were pushed in with the water hydraulics. Blowing through the water pipe or telltale can not remove them as the water exit passages have more volume than either place.
After the water leaves the pump it travels up the water tube to the lower cowl , at that point there is a rubber grommet sealing the tube to the cowl which seldom gives trouble but on engines after the serial #1742746 there is a nylon washer on top of the grommet which melts on a overheated engine and limits water flow.. Engines with a flush on the cowl will have limited flow at the flush, when this is the problem. At this point there is the powerhead gasket which I have never found one leaking, the water makes a 90 degree turn and goes to the exhaust cover for pre warming after warming it travels thru passages thru the exhaust divider plate into powerhead cools the engine and is dumped into the exhaust at the bottom of the exhaust divider plate and out the lower unit. Normally impeller parts are found in the area of the exhaust cover but when we do a engine with this problem e will take the time to check the nylon washer, exhaust cover and the passage into the power head which means removal of the water jacket cover to be sure. It?s much easier than taking it apart a 2nd time.
