samm835
- Dec 12, 2006
- 575
I am purchasing a new motor(to me) soon. I don't have a cylinder compression device, but a local auto part store will let me borrow one for the day. I know main things to do/check, foot oil, cking wire corrosion, but I need to also make sure I am checking the compression the correct way. I have never used one, but I have seen them used. Please correct me or point me in the right direction of use, here is what I know....un-screw one spark plug at a time, and insert the compression ckr in, turn over motor a couple of times(without starting). I should go through all cylinders the same. The compression should read 110 or better with little varience. I think I read that it should be within 10PSI on each cylinder? Thanks for any help!
