throttle question
jlsmith
I just bought a new boat to me a 98 bass tracker pro team 175 it will shift into forward just fine when the motor is not running but will not shift into reverse I didn't know if this was normal with the boat not running. I just had the water pump replaced and was afraid someone did something wrong.
jlsmith
Re: throttle question
I read on the internet where it must be running for the dog to catch to allow it to go into reverse didn't know if this was true or not becasue I can't remember if it would go into reverse before the water pump was replaced.
the throtle should be able to move in froward and reverse when the motors off. i can do it with mine.
BaileysBoat
Normal to have poor shifting with the engine off. Without engine rotation the shift dogs don't always line up.
JB
Care to give us the make and model of the outboard so this can be moved to the correct forum??
Exactly. Depending on where the clutch dog is in relation to the gears when the engine stops it may or may not move into either forward or reverse. What matters is that it moves into both forward and reverse when the engine is running.
steelespike
if you rotate the prop a little the dogs should drop into place.If you rotate the prop by hand while in gear you will note about 1/4 to 1/3 free rotation.
