Rapson
- Dec 23, 2009
- 50
I have a Yamaha 2 Stroke 140HP 1987 Model that is overheating. When I cruise at over 4000rpm the buzzer will go off after a couple of minutes. I can cruise under that with no problems.
A bit of history. I have owned the outboard for around 9 months. Had no thermostats in it so I installed some brand new ones (have removed and still overheats). Original gearbox had water in the oil and had a dodgy weld repair done to it and the prop was welded/coroded on and we couldnt get it off with sledge hammers so I found a second hand gear box with a new prop and installed a new impeller with it.
Never had an over heating issue with the old gearbox, only since installing the new gearbox. Got a feeling it could be the impeller but it is brand new and I did have the same impeller on the old gearbox for a short time with no issues.
Any hints on where to start trouble shooting would be appreciated. Going to drop the leg off today and inspect the impeller and go from there. Is it worth taking the cylinder heads off to inspect the water channels?
