Re: want to convert short to long shaft
What kind of motors do you have?
Are you planning to shift the lower end off of the long shaft engine over to the short shaft engine? The things that I can remember (I've done a long to short shaft conversion on 40's) were:
Shift rod
Water tube(s)
Driveshaft
1 mounting bolt that's longer on the long shaft
The 5" spacer that makes the leg longer.
It's not a hard job, if you have all of the parts already.
