aarongreen123
- Jul 23, 2010
- 133
i have a 1972 9.5hp Johnson. I want to make an attemp at working on this thing myself, but i don't have any outboard experience. i know this motor hasn't been run in at least 5 years, so i decided to replace the impeller before doing anything else. this morning i took the lower unit off and it seemed to come apart as described in other posts i found. do i just need to replace the impeller or are there other parts that should be replaced also? i expected to find a gasket between the impeller housing and the plate that it mounts to, but there wasn't one, should there be one there? i didn't see it in the diagrams i found online but the impeller repair kits seem to have one included. i didn't notice any other o rings other than the one at the top of the drive shaft. the kits also a couple other rings/seals. i'm happy to just put the thing back together the way it was, but between the age of the motor and not knowing who worked on it before, and my inexperience, i wanted to confirm. thanks for any info you can provide.
