Leaking Mercruiser Trim Cylinder
Charger183
One of my out-drive trim cylinders has started to weep fluid from the joint between the forward hose mounting section and the cylinder. It's very slow but it's there. Can someone give me a site to see an exploded view or is there a way to tighten up the joint. I know you can tighten the <br />other end but don't know and won't try to turn the cylinder untill I do. Tnx. Larry
Re: Leaking Mercruiser Trim Cylinder
It's a solid, press-fit body........<br />Time for a replacement.................
