puddlesplasher
- Mar 19, 2009
- 47
Hi All,
How do I manually start my Johnson 30hp electric start outboard?
I know it sounds stupid as its electric but there was a problem with the batteries at sea and the engine wouldn't start.
I took off the engine cover and wrapped some cord clockwise around the flywheel after inserting the knot into the groove.
Then I moved a little red lever at the front of engine from inline to across the pipe (thats as much as I recall the mechanic telling me to do)
Ignition on and then tried to start the O/B by pulling.
No joy so I need to know if I was doing something wrong. I was advised that this procedure will work on a reasonably hot outboard. This one had not been run in about 1 hour.
Thanks.
ps. the auxilliary O/B got us home.
Thanks.
