worn boot
senorboat
Hi guys i am new to this forum. Im not to sure on how this community works. I am planning on buying a 1984 galaxie and i was told by the owner that all that needs replacing is the boot for the outdrive. Would anybody know were i can purchase this part. I have been on google looking for the part but havent had any luck.
Bob's Garage
Re: worn boot
The "boot" is located between the lower unit and the gimbal.
However, based on your question, I would submit that you lack the experience and knowledge to replace this item. This would be a difficult repair for an experienced boater without proper tools and ability. You will need to take it to a qualified marine mechanic.
Get advise from local boaters as to who you can trust to do the work.
fishrdan
Re: worn boot
If the boat has been run with bad bellows you could be looking at a lot more than just replacing the bellows, Ujoints, gimble bearing, possibly water intrusion into the outdrive. I would have this inspected at a local boat shop before buying the boat, could be a very expensive repair.
The Ujoint bellows is usually replaced as a kit, exhaust bellows, shift cable bellows, water hose.
Oh yeah, what type of drive is it, Mercruiser, Volvo, OMC?
DBreskin
Re: worn boot
For clarity, what you're referring to as the boot is normally called the bellows. I replaced mine by myself without any prior knowledge of boat mechanics; I have experience with car repair and bought a service manual for my boat. YMMV.
45Auto
Re: worn boot
If the owner is saying the bellows needs to be replaced, this is a BIG WARNING that the bellows is probably leaking and has possibly damaged u-joints, input shaft, gimbal bearing, outdrive seals, and possibly the outdrive itself.
The bellows should be replaced about every 5 years as preventive maintenance. Waiting till it starts leaking is a huge risk. As others have said, get someone who knows what they are doing to look at it before you buy a boat that could easily need several thousand dollars in repairs.
DuckHunterJon
Re: worn boot
I'd agree - at a minimum, have a survey performed by a knowledgable mechanic. Or, keep looking - not sure about where you are, but around here you can spit with out hitting a used boat for sale right now. Tis the season!
superbenk
Re: worn boot
Is everyone certain he doesn't mean the OMC transom seal on a Stringer which is often called a "boot"? I don't see any mention of the brand or model of drive. Maybe it was made clear in another thread I missed.
superbenk
Re: worn boot
If he's talking about an OMC Stringer, he should walk away for other reasons than just potentially broken hardware.
rwidman
Re: worn boot
I'm with Bob on this 100%. This is not a good "first repair job" for an inexperienced mechanic. And as others have pointed out, there may be some damage to other parts as well.
senorboat
Re: worn boot
Thank you guys for your advice a really appreciate it.. just to make sure were talking about the same part its the rubber that keeps the water from going into the engine
superbenk
Re: worn boot
That doesn't really tell me anything - the bellows around the drive shaft/u-joints does that, but so does the transom seal around a Stringer drive.
I guess since everyone else here is talking about the bellows, they know something I don't know so I'll agree with them :)
bruceb58
Honorary Supreme Mariner
Re: worn boot
Why not tell us what drive this boat has? Without it we can't help you.
senorboat
Re: worn boot
I called the guy and he told me It's a omc and it the transom seal... he told me it is slightly ripped
superbenk
Re: worn boot
While a slightly ripped transom seal may be ok, it could also be a sign of very bad things. That seal fills in the gap between the drive & the transom, so when it leaks, it leaks a lot! His boat may have been underwater or severely water-logged by that "slight rip".
Regardless, it's an obsolete & antiquated drive made by a company that has been out of business for over 12 years. I have one. Walk away & go look for a Mercruiser or Volvo unless you are very mechanically inclined, have money to play with & aren't afraid of being in the position of not finding critical parts when things break.
The black rubber "boot" around my drive is what he's talking about having a rip in it (ignore the red box around the name plate):
