Re: engine dieing
From a technical perspective, I'd say it's worth starting with some routine maintenance. Why? Just because it's cheap and easy, you may get lucky, and it generally needs to be done anyway. For example, check your plugs. They often need to be changed anyway and can become fouled or wet from flooding while in use causing engine issues.
While doing some routine stuff, look for things clearly out of the ordinary. Here is why I say this. I had a similar issue second time out on my boat. I had engine trouble all day which turns out to be the result of the engine being flooded which fouled up the plugs. The last straw was when it died back to idle but not altogether. I found the linkage between the throttle and the carbs in the motor was broken and just hanging there.
This may not be the most informative post I admit...
But, in my line of work and with any technical issue, start with the cheap easy stuff. You never know when you'll get lucky and find your whole day was ruined by a $6.00 part and some oily plugs!
Oh, and get a manual if you don't have one already. They are life savers!
