Re: 1995 115 not charging
Id say almost certainly the rectifier. Check the DC volts at the red output wire. if it stays at battery volts then pretty much confirms it.
Any chance you connected the battery with reversed polarity ... that's instant death to a rectifier
The simple non regulated rectifiers are easy to test but the combined regulator and rectifier not so
