Hello, Have received (and hopefully given) great advice on other forums in iBoats, but this is my first visit to pontoons. I am considering buying a pontoon fixer upper (2001 Sweetwater Challenger 180 ES with 60hp Mercury Bigfoot) that needs a new trim motor some wiring and other issues. The biggest concern I have is a structural transom crack that is evident. I've attached a picture I'm hoping that others experienced with pontoons might be able to advise me as to whether this is a common pontoon boat occurence that can be fixed by welding and reinforcing the crack. Or if it would be your recommendation that this should be a no go for purchase. The price seems to be what is indicated when looking up the NADA value for the boar without the motor. Of course with the work it needs, it's tough to value. Any opinion on the transom crack would be helpful, and if you do believe that it is easily fixable, any recommendations on how I might reinforce the structure to prevent this in the future would be greatly appreciated.
Thank You.
Thank You.
