shekinah5678
Thread starter- Joined
- Mar 25, 2007
- 41
Hello again. My friend has a 1990 OMC 5.8L with cobra drive. He has been having trouble getting it to shift in and out of gear and sometimes even when you shift to neutral it will stay in gear. I lowered the idle and that helped it to shift but still not rite. I took a look at the shift assist module and found that it wasn't even plugged in. I plugged it in and presto all was good. However I took the boat out for a test run and it stopped working. I found that the module is working intermitently. If I moved the wires around it would work for a while and then stop. I could just tap on the module with a wrench and then engage the rocker switch manualy and it would work for a while. My question is should I just go ahead and change the module out? It doesn't look that old to me the wires are all clean and you can still see the stickers. I wonder what could have made it go bad? I'm pretty sure the motor still has the stock points distrubuter but I will double check to make sure.
Thanks in advance!
Thanks in advance!
