SteveH_1919
- Jul 31, 2010
- 31
I replaced the dead Mercruiser 5.7l with an aftermarket long block. The engine is running and I have set the timing . All of this was accomplished on the trailer with the muffs.
The engine has about 1/2 hour total run time all at varying RMP all less than 1500RPM.
The next step is to float test at the boat ramp for another 1/2 hr or so at more varying RPM all less than 2000.
I have been using the following scheme:
Idle
1000
1300
1500
idle
repeat for about 10min.
I then find something wrong and have to fix the problem (bad alternator, no indicated temp, no indicated oil pressure)
The new engine manual calls for the 2-5 hr period to be run at less than 3000RPM and varying speeds.
Is there a sticky/web site etc that goes into better detail on engine break in?
I plan on babying the engine until 5 hrs then up to 4000RPM until 10 hrs.
Ideas?
Thoughts?
Or did just open the flood gates like the oil type threads?
Thanks,
Steve
Idle
1000
1300
1500
idle
Ideas?
Thoughts?
Thanks,
Steve
