Boat had been sitting quite a while. Put good charged battery in it and it started righ up. Problem was the throttle cables were stiff and it started at a very high rpm. Pulled throttle back immediatly but oil alarm started going off. Oil levels are good, checked level switch in tank cap and its good. In reading about this problem I believe the drive gear may have sheared. I want to hook up a tank of premix before I go any further. Any easy way to drain the carbs of the gas that is in them now? Also if the drive gear is sheared, how do you get all the pieces out? I really want to keep the oil injection system the way it is. It has worked fine for a long time. Thanks.
Ed
Ed
