Hi,
I'm up on Lake of the Woods and would greatly appreciate an educated opinion on what is going on with my motor. This evening, I ran approximately 10 miles to a section of the lake, fished a spot for 30 minutes, then fired up the motor to move to the next spot. When I gave the motor some gas an alarm went off. It wasn't a constant beep, it just kept on beeping. I can't remember for sure whether this is the oil alarm or the engine heat alarm. So, my first question is which alarm this is.
Next, the motor is getting oil (as indicated by the usual smoke coming out of the engine), the oil reservoir on the engine is full (pulled off the cap and checked) and the main reservoir in a compartment of the boat has plenty of oil in it. The float under the cap of of the oil reservoir on the engine seems to move freely and there seems to be a good seal on the oil system because when I take the cap off the main oil reservoir in the compartment of the boat (as opposed to the one on the engine), it releases pressure.
After checking all this stuff and making sure the pee stream was good coming out of the motor we ran the boat 10 miles back to the resort without problem other than the annoying alarm going off the whole trip. I disconnected the power to the cap of the reservoir on the engine when I got back, fired up the engine again, and the alarm still went off.
Any idea as to what this might be? One guy I talked to said it was likely just a faulty sensor or a short of some kind. Sound possible?
I'm going to try and take the boat to a mechanic in the morning, but that is a pretty big chore and I'd really appreciate an educated opinion on what is going on with my motor as soon as possible.
Thanks in advance!
-Chris
Thanks in advance!
-Chris
