Re: Alpha 1 sterndrive fit in MC1 gimble housing?
I have a alpha gen 1 hooked up to prealpha gear on my 79 glastron...no problem
There are two things to check:
There was one shaft length for V8s, and a shorter one for other engines. Choose the one that matches you application (IE: Use the one which came off the MR if it is longer or shrter). This is due to a different engine coupler used.
Check the drive ratios. There are a few ratios given different engine sizes. If the ratios don't match, don't panic...a friend had one reratiod for $300. Check your local dealers on that one.
Chay
