Re: how to cold start 88 spl/ trim issues
i mentioned it because strong fuel odor when go to start
whats warm up handle? advancing throttle lever? thats the way my glastron manual says to start it- no mention of using choke in their description- one way i want to try ...or the red lever near the carbs?
has a new battery just trying to eliminate any possibilities ..battery on charge right now
The strong smell of fuel usually indicates a fuel leak which is dangerous. Put a little steady pressure on your primer bulb and make avery careful inspection of the system all the way to the carburetors.
You don't have chokes, you have a primer solenoid, which allows extra fuel to be injected directly into the intake manifold, bypassing the carburetors. The normal operating position of the red handle on the primer solenoid is aligned with the cylindrical base of the solenoid. It should be activated by pushing in on the ignition key.
When your control does not have a warmup lever, it usually has a shift override of some kind, either a button in the center of the arm that you can push in or a means of moving the arm to the side. Once the override is engaged, you can advance the throttle arm which will advance the timing on the engine.
