Hello iboaters,
just got back from the cabin and have bad news. Let me lay this out in cliffsnotes.
- starts perfectly, idles fine.
- when in gear it gets to aprox half it's normal speed, even if I throttle all the way open, it just won't get any faster. It isn't REVVING higher just stops getting faster and stays revving the same. The throttle indicator is not stuck, as you can see it moving to WOT on the outside of motor, just limits its speed like mentioned above.
-primer bulb gets hard initially [not ROCK hard, but hard]. after motor starts it looses it's stiffness after you shut it off, i read this is normal though?? Tank is vented while running
There were no visible cracks/leaks in the hoses anywhere. We tried with TWO DIFFERENT gas tanks and tank lines, so it's not an issue with the gas tank or bulb.
It was at mechanics for lower end recently work and he said he's never seen an old motor run like this, meaning very strong/good [it has VERY FEW hours on it in its life, has been rebuilt about 5years back too].
I have the service manuals for this motor, but not sure what I'm checking for diagnosis!? I've just researched similar problems regarding this, but still no dice, as all problems are different. Is it just not getting enough gas sent to motor? The fuel filter is clean.
EASY RANDOM QUESTIONS:
-How do you know if your motor is only running on one piston?
-Is it bad to run your motor if this condition is occurring? [ie: half speed regardless of your throttle position]
Thanks forumites!
EDIT: Before anyone may suggest "rebuild carb and check your high speed jets", a little more might help. Even though I have the manual, I've never done that and not an outboard mechanic by any stretch, even though I'm trying to learn
Thanks forumites!
