skid_68
- Jul 21, 2010
- 13
I've seen some people mention that they pack their tilt clutch housing with marine grease instead of filling it back up with oil in order to keep water out. I plan on doing this, but have a question. I read somewhere that some one drilled a hole in the housing, and installed a grease zerk fitting so they could pump that sucker full of grease. Does anyone else recommend doing this? Where would you drill and install the zerk fitting? Would you take the oil fill cap off while pumping grease in there to insure that the air is going out, and the grease is going in? Thanks.
Paul
Paul
