Re: Carb rebuild / clean
I just rebuilt mine on a 1996 merc 3.0. I am assuming that since you are asking that you haven't done it before. I hadn't either.
Take your time, take some pictures. the parts I had a hard time remember was the linkages on the outside. I didn't take as good of pics as I should have.
Pay attention to what size gaskets come off as you may get a lot of ones you don't need in a carb kit.
Make sure you have some good screwdrivers. My carb had phillips head screws that were painted over, they were kind of tough to get off with out a properly sized screw driver.
I had a hard time getting the main jets & needle seat out. I guess since they had been in there over 10 years they were in there really good. Again, a really wide screwdriver was needed. I almost stripped the main jet out trying to get it out.
Measure your float drops carefully.
The carb adjustments also gave me a little bit of hassle. It took me a few times out to fine tune it. I finally got some good advice on here and it runs awesome now. here is the link to my post on it
http://forums.iboats.com/showthread.php?t=415919
I assume you have the manual. I wouldn't have been able to do it with out it.
