Help Tach wont work
jeff6898
1991 Mercury 90HP
Tack will not work things checked so far
Have power to tach
have good ground
took out tach put in friends boat works perfect
put his tach in my boat does not work.
Have continuity from grey wire from motor to back of tach
Battery is charging great so I am guessing rectifier is good
boat runs and idles perfect
I see the grey wire goes into a square moduale Dont know how to test that piece whatever it is.
Any suggestions?
NYBo
Re: Help Tach wont work
Sounds like a question for the Mercury outboard section.
Barnacle_Bill
Test your rectifier even tho it appears to be charging.
If you use an analog meter set it on the RX1000 scale.
If using a digital meter, set it on the diode symbol.
1. Disconnect the battery leads.
2. Disconnect all wires on the rectifier.
3. Connect the red test lead to ground and the black lead alternately to terminals A and C.
The meter should show continuity.
4. Connect the black lead to gound and the red lead alternately to terminals A and C.
The meter should not show continuity.
5. Connect the black lead to terminal B and the red lead alternately to terminals A and C.
6. Connect the red lead to terminal B and the black lead alternately to terminals A and C.
7. Replace the rectifier if you do not get correct readings.
jeff6898
Ended up replacing the rectifier and it now works perfect.
