Re: New to me 5.0L cobra drive. need help!
DB electrical.com
02-28-2011 Starters > Marine Inboard > OMC Marine > 4.3 Liter > Marine Starter V6 V8 GM 2 Long Bolts Mercruiser OMC SDR0031
Price: $53.00
Quantity:
New Inboard Marine PMGR Starter for
Mercruiser, Volvo Penta, Others
Comes with mounting bolts - Offset bolt pattern. -
This marine boat starter fits nearly all Mercruiser, Cobra,
Yamaha, Volva Penta, and OMC GM engines except the 3.0 liter.
This permanent magnet high torque gear reduction starter will
also replace the older large style 10MT Delco starters with
staggered (offset) bolt pattern! It provides higher torque with
less drain on your battery.
Fits Merc, OMC, Volvo V6 & V8 engines- GM Block using a
14.5 inch flywheel. High Torque Gear Reduction with staggered
bolt pattern. This starter has an 11 tooth pinion that will replace
the older style 9 tooth models.
Replaces these part numbers:
API Marine # 10095, 10099, ST95
Arco # 30450
Delco # 9000819, 9000821, 9000839, 9000840, 9000884
Mercury # 50-806964A2, 50-806964A3, 50-806964A4
50-807904A1, 50-812604A2, 50-812428A3,
50-822330A2, 50-807907
OMC # 3854751, 3855177, 3856004
Volvo Penta # 3587625-10, 3854751-9, 3856004-1, 3860764
Sierra Marine # 18-5913
Will also replace these older style 10MT Delco starters
Mercury # 50-12121A2, 50-12177A2, 50-712428A3,
50-812604A2, 50-99418A2
OMC # 984456, 986505, 3850525, 3853982, 3855177
Fits all of these applications and others:
OMC Marine
ENGINES - MARINE All Models 4.3L 1987-1996
ENGINES - MARINE All Models 5.0L 1986-1988
ENGINES - MARINE All Models 5.7L 1986-1996
ENGINES - MARINE All Models 7.4L 1990-1996
ENGINES - MARINE All Models 8.2L 1988-1992
VOLVO PENTA Marine
ENGINES - MARINE Various Models 4.3L 1995-1999
ENGINES - MARINE Various Models 5.0L GM 1998-1999
ENGINES - MARINE Various Models 5.7L 1996-1999
ENGINES - MARINE Various Models 7.4L 1996-1999
ENGINES - MARINE Various Models 8.2L 1996-1999
MERCRUISER Marine
Hi Performance
Model 377 Scorpion (Gen+) (Ski) GM 6.2L - 377ci - 8cyl
Model 377 Scorpion Sterndrive GM 6.2L - 377ci - 8cyl
Model 450 (Gen V) GM 7.4L - 454ci - 8cyl 1995-1996
Model 500 (Gen +) GM 8.2L - 502ci - 8cyl 1999-2000
Model 500 (Gen V) GM 8.2L - 502ci - 8cyl 1994-1996
Model 500 (Gen VI) GM 8.2L - 502ci - 8cyl 1997-1998
Model 500 Bulldog GM 8.9L - 540ci - 8cyl 1990-2001
Model 500 EFI GM 8.2L - 502ci - 8cyl 1999-2002
Model 525SC (Gen V) GM 7.4L - 454ci - 8cyl 1996
Model 525SC (Gen VI) GM 7.4L - 454ci - 8cyl 1997
Model 575 SCI GM 8.2L - 502ci - 8cyl 2000-2002
Model 600SC (Gen VI) GM 8.2L - 502ci - 8cyl 1997-1998
SKI ENGINES
Black Scorpion Ski (Gen +) GM 5.7L - 350ci - 8cyl 1996-1998
Model 350 Mag EFI Ski (Gen +) GM 5.7L - 350ci - 8cyl 1996-1997
Model 350 Mag EFI Ski (TBI) GM 5.7L - 350ci - 8cyl 1994-1996
Model 350 Mag MPI Ski GM 5.7L - 350ci - 8cyl 1995-1996
Model 350 Mag Ski GM 5.7L - 350ci - 8cyl 1991-1997
Model 454 EFI Ski (Gen V) GM 7.4L - 454ci - 8cyl 1995
Model 454 Mag MPI Ski (Gen VI) GM 7.4L - 454ci - 8cyl 1996-1997
Model 5.7L Competition Ski GM 5.7L - 350ci - 8cyl 1987-1997
STERN DRIVE
Model 200 GM 5.0L - 305ci - 8cyl 1987
Model 230 GM 5.0L - 305ci - 8cyl 1987
Model 260 GM 5.7L - 350ci - 8cyl 1987
Model 262 Mag (Gen +) (TBI) GM 4.3L - 262ci - 6cyl 1996-1997
Model 350 Mag Alpha GM 5.7L - 350ci - 8cyl 1988-1995
Model 350 Mag Alpha (4-BBL) GM 5.7L - 350ci - 8cyl 1996-1997
Model 350 Mag Alpha EFI (Gen +) GM 5.7L - 350ci - 8cyl 1996-1997
Model 350 Mag Bravo MPI GM 5.7L - 350ci - 8cyl 1995
Model 350 Mag Bravo MPI (Gen +) GM 5.7L - 350ci - 8cyl 1996-1997
Model 4.3L (Gen +) GM 4.3L - 262ci - 6cyl 1996-1997
Model 4.3L (Gen II) GM 4.3L - 262ci - 6cyl 1994-1996
Model 4.3L (Gen II) (2-BBL) GM 4.3L - 262ci - 6cyl 1993-1996
Model 4.3LHX (Gen +) (4-BBL) GM 4.3L - 262ci - 6cyl 1996-1997
Model 4.3LX (Gen +) (2-BBL) GM 4.3L - 262ci - 6cyl 1996-1997
Model 4.3LX (Gen II) (4-BBL) GM 4.3L - 262ci - 6cyl 1993-1996
Model 454 EFI (Gen V) GM 7.4L - 454ci - 8cyl 1994-1996
Model 454 Mag Bravo (Gen V) GM 7.4L - 454ci - 8cyl 1992-1996
Model 454 Mag Bravo (Gen VI) GM 7.4L - 454ci - 8cyl 1996-1997
Model 454 Mag Bravo MPI (Gen VI) GM 7.4L - 454ci - 1996-1999
Model 454 Mag MPI (Gen VI) GM 7.4L - 454ci - 8cyl 1996-1998
Model 496 Mag HO GM 8.1L - 496ci - 8cyl
Model 496 MagI GM 8.1L - 496ci - 8cyl
Model 5.0LX GM 5.0L - 305ci - 8cyl 1988-1995
Model 5.7L (2-BBL) GM 5.7L - 350ci - 8cyl 1996-1998
Model 5.7L Bravo GM 5.7L - 350ci - 8cyl 1989-1995
Model 5.7L EFI (TBI) (2-BBL) GM 5.7L - 350ci - 8cyl 1996-1997
Model 5.7L EFI (TBI) Alpha GM 5.7L - 350ci - 8cyl 1995
Model 5.7L EFI (TBI) Bravo GM 5.7L - 350ci - 8cyl 1995
Model 5.7LX (4-BBL) GM 5.7L - 350ci - 8cyl 1996-1997
Model 5.7LX Bravo EFI (Gen +) GM 5.7L - 350ci - 8cyl 1996-1997
Model 5.7LX EFI (TBI) (2-BBL) GM 5.7L - 350ci - 8cyl 1997
Model 5.7LX EFI (TBI) (4-BBL) GM 5.7L - 350ci - 8cyl 1996-1997
Model 502 EFI (Gen V) GM 8.2L - 502ci - 8cyl 1993-1995
Model 502 Mag Bravo (Gen V) GM 8.2L - 502ci - 8cyl 1992-1993
Model 502 Mag MPI (Gen VI) GM 8.2L - 502ci - 8cyl 1996-1998
Model 502 Mag MPI Bravo (Gen VI) GM 8.2L - 502ci - 1998-1999
Model 7.4L Bravo (Gen V) GM 7.4L - 454ci - 8cyl 1992-1996
Model 7.4L Bravo (Gen VI) GM 7.4L - 454ci - 8cyl 1996-1997
Model 7.4L MPI (Gen VI) GM 7.4L - 454ci - 8cyl 1998
Model 7.4LX Bravo MPI (Gen V) GM 7.4L - 454ci - 8cyl 1996
Model 7.4LX Bravo MPI (Gen VI) GM 7.4L - 454ci - 8cyl 1996-1997
Model 7.4LX Bravo TBI (Gen VI) GM 7.4L - 454ci - 8cyl 1996-1997
Model 7.4LX MPI (Gen V) GM 7.4L - 454ci - 8cyl 1996
Model 7.4LX MPI (Gen VI) GM 7.4L - 454ci - 8cyl 1996-1997
Model 7.4LX TBI (Gen VI) GM 7.4L - 454ci - 8cyl 1996-1997
? 2010 DB Electrical Starter-Alternator
