CoastalPete
- Jul 2, 2010
- 51
Oh no, more problems now, troubleshooting within this forum why my engine stalls under load led me to clean & rebuild carbs (carbs looked good apart except for the high speed orifices that were found very loose), now it?s not running as smoothly in lower speeds as it was before, although initially it appeared stronger/more responsive at higher rpm's in neutral so I thought that was it, but it still stalls under load when you approach 1000 rpm's. I assumed it was not running right due to the lean/rich adjustment so I have been trying to get that right, which I thought I got it running a little better in idle, but last night went back to boat to work on it some more and now find what looks to me like some mild moisture on the carbs butterfly (throttle valve) and milky fuel on the throat of the carbs (never had that before carb rebuild & fuel is good) and a couple of the carbs are leaving fuel on the back side of the air cover? Is this water from somewhere or from running too lean or now sucking in air (I cut one tie wrap off the fuel pump when I thought for a second about pulling it off to have it tested but changed my mind and forgot to put another tie wrap on, will do next time)???
I also tried a couple of new things such as pushing in the choke to see if it would run better in idle or under load and engine dies on each, also placed my hand over each carb very briefly and very good suction as fuel comes out, that?s where I noticed the mild milky substance. I checked to see if the carb throats opened all the way at 90 deg., they are close, I would say about 80 deg., however, they do not really begin to open until the shifter is about 75% moved forward? The motor will start every time no problem and idle ok, but now even when I rev it up a bit in neutral it does not sound right, I am growing very concerned. I have also recently noticed every few seconds a burst of water shooting out the exhaust? Lastly, I definitely noticed the starboard side of motor is much hotter than the port side, but when I disco the temp sensors on each side while under load it has no effect so I very briefly pulled spark plug off on port side while under load, seemed to have no effect on engine performance, however I did hear taping and felt the electricity on the coil wire arcing to the plug, also did this on starboard side and noticed engine ran weaker and coil arc to plug was stronger than starboard side, this leads me to think maybe its not the link and sync and I should be looking at ignition, such as power pack, timer base, coils and/or stator.
Please let me know what you guys would do...listed below is some history of what I have done so far on my 1994 Johnson Ocean Runner 225:
1. Decarbed engine and added new fuel filters and plugs,
2. Ran clean fuel direct to fuel pump on motor,
3. Pumped fuel ball under load and its tight, made no difference,
4. Compression Check ok (all between 90-100),
5. Checked spark on each cylinder (V6) ok, also checked at night, no arcs,
6. Timing checked ok,
7. Checked it?s not the shift interrupter,
8. Replaced fuel pulse limiter (strange how the engine then failed under load at higher rpms 2800, then failed under load at lower rpms 1000 after carb rebuild?),
9. Cleaned & rebuilt all carburetors,
10. I do hear the fuel pump click every 5-10 seconds, heard it should be more like 20-30 seconds, so still not sure if I should pull & bring to shop to test. Pump ball and she stays pretty hard, both in neutral & under load.
Thanks,
Pete
Thanks,
Pete
