All,
I started my '85 Ev 140 VRO for the first time in 3 years. It turned over, but then I shut it down to learn more about what to look for to make sure the water pump is working.
I ran it for about 20 seconds. Water peed out of three holes in the back of the lower case, 2 under the anti-cavitation lip and one just above the lip. See photos.
Is that an indicator that dangling there that should be plugged into the hole above the lip?
I did not see water come out of the exhaust. Is that possible because the engine was not running long enough?
Is it normal for the water to come out of the pee holes immediately, but for there to be a delay before it starts coming out of the exhaust? If so, how long should it take for the water to come out of the exhaust. Does this indicate the thermostat has opened to allow water to start circulating around the engine?
