wingrider78
- Jul 4, 2010
- 3
Hello all, I have a 2003 Bennington 20 foot pontoon. I bought it in 07 and have been loving it for 3 years now. Today, I noticed some damage to one of my pontoon tubes today when I pulled it out of the water. I have a bunk style trailer and every so often the wind or waves will push the back end of the boat over the bunk as we pull it out, leaving the back end sitting on top of the bunks instead of resting between them. When it happens, I just jump out of the truck and put a little body weight against it and she falls into place. When I did that today I happen to notice the tube looked different as it rested on the bunk, it looks a little bulged out when looking from the side. When I looked underneath I found this...
I can honestly say that I probably have never looked at the tubes from that angle before and I suppose that it could have been there before I bought the boat 3 years ago. I bought it from a guy who didn't have a trailer and he had a lift that two bunks going perpendicular to the tubes, one in the back and one in the front. So I never got a look under the tubes. I notice now that there are small dimples in the bottom of the tubes, about 4 feet from the front of the boat too, possibly from the lift??? I would imagine that if I did that damage today, I would have heard the tube getting bent out of shape, I didn't hear anything.
What are some steps to take to make sure the tubes are still sealed properly, no leaks or broken welds anywhere??? There are screw in plugs on the top of each baffle of each tube, 6 in total for both tubes. Here is a picture of the plug
Should this be fixed and pulled back out? Anyone have an approx cost that i'm looking at to get the pulled out and fixed? Are the tubes pressurized at all? Can I just pull the plug out at midday and see if the expanded air (due to extra heat at midday) comes out of the tube? and if it does, there isn't a leak...any ideas?
EDIT: I suppose I should mention that I think the boat pulls a bit to the left and always had...I have always assumed it was due to extra weight on one side of the pontoon due to the gas tank on that side...
