svillebrian
- Jun 29, 2008
- 41
I have a 2001 90hp 60 degree with optical ignition
Here's how it all started... Was having a little problem with the motor shutting off occasionally while idling. Ran good w.ot.. The last time i did run it hard, the "hot" alarm went off due to a grain of sand in the pee hole. Imediately shut it off, and fixed that issue, and boat still ran fine the rest of the day. got home that evening and noticed that the carb bowls were leaking, due to them becoming warped. Next day, pulled them off and cleaned them good, went ahead and put a new kit in them since I had gone that far, and bought 4 new bowls. Put them back on, and boat cranked and idled fine. Took it out on the river, and did fine at idle. Gave it the throttle, and got up on plane good, but once i hit 5000 rpms it dropped off and wouldnt get over 4500 rpm. ran good at this point, just wouldnt get anymore rpms. took it home, talked to some people, and thought maybe i didnt adjust the floats right. Pulled the carbs off again, and readjusted the floats (with carb turned upside down, the free end just slightly higher than the pin end). Reinstalled them and ran it on the muffs, and it was idling fine. went ahead and ran some sea foam into the gas line directly, let it sit for 5 min and then cranked it back up, once the smoke cleared it ran good at idle. Went ahead and put a new fuel water seperator on it, and put new plugs in.Took it back to the river, and this time it would not get over 2000 rpms. Ran good but just started bogging down and dying if i tryed to get over 2000 rpms. I have since then checked the compression, which all cylinders were between 120 and 125 psi. I put an inductive timing light on all the plug wires, and seem to be getting a good consistent signal up to 4000 rpms (which i could occassionally get to briefly). Last season, i replaced the fuel pump and 2 years ago, I replaced the power pack and optical sensor. Any suggestions on where I should go from here?? I dont know what would be causing it to keep bogging down?? please help me before i go crazy and take a match to this thing... I will stay online for awhile to respond to any questions or advice.
