FairwayFatty
Thread starter- Joined
- Jun 20, 2010
- 4
How can I tell what prop I have on my 2006 Merc 115 ELPT 4S motor? I am the second owner. This motor came from dealer installed on a Premier 23' 225 Pontoon Boat (I bought this setup from original owner). It pushes this pontoon boat fairly well but I notice other pontoon boats of same length with similar or smaller motors seem to run a bit stronger/faster.
I ran a prop wizard and it said a 14 X 13 for water sports or 13 3/4 X 15 for speed. I'm just trying to figure out what the factory prop is. Would it be setup with a particular prop for a Pontoon? The existing alum. prop also has some heavy nicks and gouges from all of the stick etc. in the lake. I also notice that a discount prop retailer stated I must buy a "hub"... Is that a common set up to have to use this hub (I'm guessing it is and some kind of a splined adapter?)
Anyway....just looking for some insight and i a new prop might help the boat run better.
Thanks. FF
Thanks. FF
