Hi Thanks for viewing I just got home with what I hope to be a true steal. I purchased a 1984 Cobia Bowrider on a galvanized single axle trailer with a 1976 Evinrude 115 horsepower outboard engine for 500 dollars. I honestly feel like the boat which is in great shape and the trailer are well worth the 500 i paid. My search for input is pertaining to the outboard. It is the main reason the boat sold for so cheap. The sellar was under the impression that the cylinders do not have full compression. The symptoms described by him were that the engine would crank and then you would immediatly have to put it in gear and raise the rpms or it would die. Its been sitting up for a year but those are the symptoms it had last year when he was out on it. He mentioned the power didnt seem like it was 100% but also said he had never had a mechanic look at it. The cylinder heads have not been tested for compression so that is not a definet. My question is do these symptoms sound like a compression issue or something with the carbs. I do not know anything about outboards so any information will be much appreciated. This is my first motorboat and I am truly hoping I have not gotten in over my head to get it out on the water running. Thanks alot for any advice and diagnostic help you can give I will update with info as I get it.
Josh
Josh
