1976? mercury 850 problems
huntingnemo05
Hi if anyone can help me i would like some advice on my 850
the motor has spark and fuel just wont fire and run if it does fire and run it only stays running for about twenty seconds any ideas out there
chum1
Re: 1976? mercury 850 problems
possible air leak in fuel system or faulty diaphram in fuel pump. Could be just burning up the fuel in carburetor bowls then dying.
SeaKaye12
One quick way to check if its a fuel issue would be to continuing to squeeze the ball once the engine starts and see if that keeps it running.
If so; you know it's fuel starvation.
Then; you'd want to check and double check everything in the path of fuel...from the pick-up in the tank to the hoses that connect to the carbs.
Look for obstructions and/or air leaks.
You have the vent in the tank open; right?
Good luck, Chuck
abarron
How ya doing?I myself have a 850 74 model i would take it out on the lake and it would bog down and quit,my son was with me and noticed the bulb squeezed shut when it would run and start to bog,he pumped the bulb and it would pick up.Anyway it was my inboard tank trashed.I hooked it up to a 5gal tank and run SEAFOAM in it.Now it runs great! I'll ether pull the tank and clean it or install a new one.Hope this helps!;)
huntingnemo05
hey guys
thanks for all the help you guys are giving me going to take the boat to the lake this weekend and hope for the best
