MODEL #: J70ELCSA
I bought a Bayliner with this motor on it, and it looks very clean - I had it on the earmuffs and it ran fine. Maybe a little cold blooded. I attribute that to the few moments I ran it on last-year's gas.
I opened it up, checked the plugs; they needed replacing - did that today. They were beyond worn (about twice as much as the recommended .030 gap - at least that's what the guy at NAPA told me).
OK, so my questions are pretty basic.
#1 - The fuel mix is simply 50:1, right? It's a single tank under the transom, and from what I've read through here, I believe it's 50:1.
#2 - Can I run seafoam or stabil through the gas to help "clean it up inside"? Will that harm the gas-oil mix? If so - how much should I add to the tank? If not, what's an alternative?
#3 - I'd also like to drain and replace the lower-unit gear oil. The marine shop has this (what looks like generic) marine-lower-unit oil, some 75-80W or some such. Says its good for OEM Johnson/Evinrude. Any concerns there? A friend said to get the motor exactly level, drain it, then fill it back up till its even with the fill screw hole. That sound right?
#4 - is it safe to put teflon tape on the fill-screw and drain-screw screws for the lower gear unit after I've done the oil replacement?
If I had any complaints about the few moments I ran it, I'd say it was either starving/flooding - sort of boggy. I'm going to attribute that to the crap gasoline, the very-worn plugs, and probably a fuel filter that needs love. Tomorrow I'll replace the fuel filter, as well as check the fuel fittings to make sure there's no leaks.
All in all, it ran well, and started right off. I can't complain one bit. Just looking at this thing, it looks like a solid workhorse, and I'm impressed with the shape it's in for a 30 year old motor.
