identifying my motor 3.0l or lx
mickrex
hi there i have a 1990 mercruiser 3.0 how can i tell if its an l or lx model the engine serial no is oc605198 i am trying to sort out ignition problems and the ignition control box has different part numbers between the two models being 18811t1 for the l and 18811t2 for the lx naturally my control box no is unreadable
thanks mickl
atomb
Re: identifying my motor 3.0l or lx
im no expert and dont know if you have the lx or the l but from what i understand the real difference is in the cylinder head. hmm igntion control box---module ...I think depends on if you have a electrnic spark i beleive or digital ignition .sorry i couldnt be of more help.
mickrex
it has the ddis ignition system which is proving extremely hard to source in the uk so i will have to import parts from the us so i need to get the right parts hence i need to know if it is an l or lx.
mick
Fun Times
thanks mickl
mick
Hi, You are looking at the wrong part numbers for youe engine.
Going by your engine serial number and going by Mercruisers service bulletin number (95-11) the correct part number for your engine control module is (18811T).
The part numbers (18811t1 for the l and 18811t2 for the lx) that you are looking up are for engine serial number OC856559 and above.
Your engine serial number is below OC856558 So that makes your engine a 3.0L, And that makes your engine control module, part number (18811t).
Your engine specs are as follows,
(1) module advance: 26 degrees.
(2) initial timing: 8 degrees.
(3) total advance timing: 34 degrees @ 2600RPM's
Here is a link to your service bulletin, Yours is the second page down, Then read the next three pages down.;)
http://www.boatfix.com/merc/Bullet/95/95_11.pdf
xltier
i think the lx takes the long spark plugs.a-c #mr43lts.
mickrex
thanks very much for your help i managed to track down a control box but its for a lx motor unfortunately so i guess my best bet is to throw the ddis system and fit a distibutor and coil from an 87 3.0 i have been offered so i can get my boat back in the water :)
thanks mick
mickrex
update i managed to get a new control unit for $500 inc shipping to uk :) so it looks like my old sea ray will live again .
thanks again mick
