Re: Help - Battery Not Charging
I ran the test on the rectifier. With the red lead on the base I got a reading on the red wire, but none on the yellow or yellow/gray. With the black lead on the base, I got a reading on the yellow and yellow/gray but none on the red wire. The instructions said that I should get a reading in one direction, but not the other. I took that to mean that with the red on the base I should get a reading on all wires and with the black on the base I should not get a reading on any wires (or vice versa). I got a reading on each wire in one direction though.
On the second test I got a reading on the red wire to one of the other wires, but no other readings even when I switched leads.
So, is my rectifier bad?
