SeaRay2389
- May 8, 2010
- 22
Hi I'm newly registered but a long time lurker. I need some input and ideas for a boat I just picked up. It is a very neglected 1989 Sea Ray 210 BR with A Mercruiser 350 (260hp) and Alpha 1. The engine is froze cracked on the block and the head. It only had 119 hrs on the meter. I was very skeptical of this for being a twenty one year old boat. But when I pulled the engine and tore into it, it was very typical of and engine with that low of hours. And it matches the numbers on the original paper work. I have a replacement for it already.
The interior aft of the cockpit is shot. because the cover was torn right in between the wind shield because they left it open. Parts of the floor is rotten in some spots. Right behind the bow walk thru and the piece in the bottom of the ski storage. Can I replace the rotten sections or should I do the whole floor? I want to replace the carpet with something else. What other options would you go with?
The transom and all the stringers are solid. The gel coal is in new condition but the paint near the cap is heavily oxidized. Can I use some sort of rubbing compound and water to bring it back?
I am the third owner and the boat hasn't been on the water for two years. The second owner is a friend of mine and he got the boat with 89 hrs on it and used it for two seasons then didn't winterize it. It is my third boat and first I\O. What would you check the out-drive for?
I picked it up for $500, boat and trailer. I'm having the upholstery redone and getting a quality cover made. Is sunbrella material the best there is or is there something better?
Thanks in advance for the advise. This is a great forum with very helpful members with a wealth of knowledge. I'll post some pictures if anyone would like to see.
