Re: 1990 Mercury 150 HP/ No water coming out
Water should pour out prop and gratings above antiventilation plate. When you have the muffs connected and the water on, engine off, water should be coming out around the muffs. When you start the motor, this should cease as the water is sucked into the motor. if the water is not sucked into the motor at all, you have a bad waterpump, or insufficient hose pressure.
