Looking at 350 based SBC's, they come in common builds from 240-350+ HP depending on builds. Given that the weight is the same, would I be safe in assuming that a higher HP engine would be more efficient in the same boat at a given cruise speed?
Howdy,
A 350 hp SB engine might be little more efficient than a similar 240 hp engine only because the compression ratio is a lot higher. That would increase the efficiency of the higher HP engine a little.
You might not notice a huge difference in fuel flow though.
Honesrly more HP means more fuel, it all depends how you use it and I must say a lot more fun.
I have 2 cars one with a 5.7 litre and one with a 6 litre, they are both exactly the same engine but the 6 litre does uses more fuel
This is probably the most usable statement here and is factual.A higher HP engine could swing a bigger prop better thus giving a better cruise efficiency.
Well I would not call a 5.7 and 6.O "exactly the same engine" as a 6.0 is of course larger displacement. This translates to more throttling (less open) for the same power output and should result in poorer efficiency than the 5.7 at the same output. The opposite is true with the bigger prop, less throttling (more open throttle) and lower RPM for the same speed = better efficiency. All on paper of course and what I am guessing the OP wants is better efficiency on the water . . . Finicky isn't hea 5.7 litre and one with a 6 litre, they are both exactly the same engine but the 6 litre does uses more fuel
what's a litre?
.... The best thing to do seems to be installing a fuel flow meter, and using a GPS for accurate speed measurements, find max speed/gph ratio. ....
You mean like this???
