installing lower unit 225 HO Johnson
ikezx14
New to the sight, First Post.
Question? 2000 model Johnson 225 H.O..... 20" shaft
I am reinstalling a re-built "lightning" lower unit and when I get the lower unit up to the midsection to bolt up, there is about a 1/8th, to 1/4 " gap between the lower unit and mid section. If I push up , It will go together, but just wanted to make sure it is ok before I torque it tight. Is there supposed to be some pre-load on the pinion shaft and thats what this is, or do I have a problem else where?? ( Don't want to put pressure on pinion bearings or race if it doesn't require it.
Thanks
tashasdaddy
Re: installing lower unit 225 HO Johnson
if it will push up, bolt it. make sure the water tube grommet is not distorting.
ikezx14
ok thanks, everything else is lined up, just needed a second opinion on final seat.
Faztbullet
Make sure it is a 92 or newer gearcase as driveshaft is different lenght. It should just slide into place with NO preload on driveshaft. Make sure you do not leave out the exhaust hsg and seal. Also if its a older unit make sure the cooling passage has been drilled as lack of water flow will melt the rubber hub in prop.
