1966 Johnson 3hp quick question
ray 6688
Hello all.
on the motor swivel bracket there is a screw to adjust the friction when
turning/steering motor.
On mine the screw bears on the top plastic bush.
Is this correct or do I have a missing part ?
Seems like there should be something to prevent the screw chewing up the top
bush.
If there is a part missing, I will make a part to fit from a bit of alloy.
Thank you.
Regards
Ray
Joe Reeves
Re: 1966 Johnson 3hp quick question
The missing part is the Friction Block, part number 310265.
ray 6688
OK thank you Joe,will make up something from hard plastic or alloy.
Regards.
Ray:)
