diy battery cables
rcl700
Where can I buy wire by the foot to make some battery cables?
I looked at lowes and the wire they have is not flexable (stiff)
any ideas?
Piedog
Re: diy battery cables
You can get your battery cable wire at any automotive parts place!
4JawChuck
Welding cables work well, they are designed for wet area use so they have a water proof sheath and are very flexible due to the fine pitch wire. I recommend sealing the ends with epoxy shrink tubing to keep them dry inside. They don't handle vibration as well as the thicker wire battery cable so make sure it is well supported.
If your using the boat in salt water buy the proper marine battery cable, each wire is individually tin coated throughout its length and resists corrosion much better.
bruceb58
Honorary Supreme Mariner
+1 on genuinedealz
I have bought a lot of wire and cables from them.
JustJason
i've got a buddy that owns a car stereo shop. I take all his scraps. You can buy monster cable and various other brands at stereo shops. Lots of braids, very flexible wire.
