74? johnson 3 cylinder 75hp
johnson301979
boat i took out it went strong about 10 minutes then bogged out and died it was misting gas out the bottom carb took spark plug out the bottom one and it was wet with dark liquid the two top ones were dry can someone help?
my motor carb holes, the bottom one is sputering gas that lookes like a milky color what could be the matter?
tashasdaddy
Re: 74? johnson 3 cylinder 75hp
sounds like you need to read ethanol, carb cleaning, compression check.
http://forums.iboats.com/showthread.php?t=299680
you have 3 carbs if they are not working properly, it is a very easy way to ruin your engine. no fuel thru the carbs, no oil to the cylinders, BOOM
Willyclay
Welcome to the iboats.com forum. Tashasdaddy and the other experts here can help you with any question about your boat, motor and trailer. I my opinion this is the single best resource for recreational boaters. The Engine FAQ thread at the top of the Repair & MTC forum page are very helpful. Good luck!
