Nandy
- Apr 10, 2004
- 2,145
I am going to politely ask that if you are not a mechanic or have experience working with this vehicle to refrain from posting your "best guess". I'm not trying to be rude, im just trying to get a good educated advise.
I have always worked in all of my cars but I need advise on this trouble before I start working on this with my limited free time. With the cold weather, being down to one "gas guzzling" vehicle, we both work 1 hour away from the house/1 hour away from each other and a very incompatible schedules this is a nightmare.
Symptoms:
The short story - Sound is a metal scratching on metal sound accompany by transmission/motor vibration but the sounds is definitely coming from the clutch/transmission case which appears to vibrate more than the motor. The vibration cannot be felt from the driver seat (see note one for exception) but can be appreciated while looking at the motor/transmission case.
* Note 1 - When this test was done with the reverse gear engaged the noise and vibration was noticeable worst to the point I could feel the vibration in the driver seat.
Noise happens when:
1. Car is stopped, transmission in neutral, clutch engaged (pedal not depressed).
2. Car is moving, transmission in neutral, clutch engaged.
3. Car is moving, transmission in 1st *, clutch engaged.
4. Car is moving, transmission in 1st *, clutch disengaged (pedal depressed).
No noise when:
1. Car is stopped, transmission in neutral, clutch disengaged.
2. Car is moving, transmission in neutral, clutch disengaged.
The long story - Yesterday the girlfriend went to warm up the car and I hear this rattling noise, not too loud... I get to the car and it sounded like that dry sound of metal-on-metal scratching sound. I open up the hood and start chasing the sound. It seems to be coming from the motor. Then suddenly the sound got real loud and it made me jump to shut the vehicle down. I check fluids everywhere as the sound was coming from the motor and I wanted to make sure it was not the crankcase or something in the internal of the motor although the sound was not of a motor that lost lubrication. I start the motor again and the noise was gone, I release the clutch with the shift in neutral and all hell broke loose again. I made the above noise/no noise test.
My guess:
The above test points me to the transmission and whatever part is moving when the transmission is in neutral and the clutch is engaged or when the clutch is disengaged but the transmission is on gear.The book for the car does not provides any information about the transmission to me to narrow down the trouble to a specific section.
The situation - Im trying to get a feel if there is anything that I can change or if I will end up getting a transmission at a "pull a part" junk yard. We were planning on getting another vehicle before anyway once the girlfriend gets her income tax return but that is at least a moth ahead and this vehicle not working mess everything. All I want is to get this car moving until then and it is not worth it for me to spend a lot of money fixing it. I cannot do a one car thing for too long as the only one with freedom at work is me but when they need me, they need me. So it will be a matter of time before she will be stuck at work waiting for me in a very, very empty parking lot, late at night... Or I will fail to fulfill my duties and I could get fired.
Life sometimes sucks but it surely beats being dead... ;-)
What do you guys think the problem could be?
Symptoms:
Noise happens when:
No noise when:
My guess:
