Hi everyone I've been lurking and searching for all my answers but have a new intermittant problem I'm hunting..
I just recently picked up an 1985 17'bonito cc with a 1985 johnson(j60ELCOD) cheap. The boat like most was neglected for a couple years. I replaced most of the boat wireing, replaced necessary wireing in the motor. Checked the cooling system its ok no overheat, cleaned and rebuilt the carbs. Replaced lower unit oil. etc..etc.. Boat would start and idle ok just seemed like it needed to be run. Finally got it on water for test run. It started just fine idled just a little rough, when I throttled up boat gained a few hundred rpm but not much and wouln not plane. Took a small loop around lake at what would be about 1/3 throttle but would not power up any more. After about 5 min pushed to wot, boat wouldn't speed up at all but stayed at low power, engine then on its own kicked up to full power and popped up on plane. Would run at wot for a while then every now and then it would drop to 1/3 power on its own. Boat would start perfect everytime, and no problem moving at no wake speed. When boat dropped power I squeezed fuel bulb with no effect on the motor. Have glass filter so I know it was getting fuel, took carbs apart again they are ok..
I'm looking for other ideas, I'm leaning towards intermittant coil issue and will test coils when I can. While searching I found some motors have a SLOW feature, does this motor? Some of my problems seem to mimic the slow shutdown I think...As far as I can tell the temp sensor on the motor has its wire cut(brown) and the alarm in the cc just has its black and red wire hanging loose.(so no active alarm system) I'll keep fighting the good fight, but was wondering if anyone has any ideas or input for me.
by the way I have a seloc(argh) and oem manuel is on its way so that is not required input lol...
