bouymarker
- Jul 24, 2009
- 24
what is the bore size for evinrude 90hp carb. and what is the next size up? i've got a pair of 1 5/16th carb.'s and want to install a size larger, what would it be.
thanks
thanks
the boat and motor were free and i've put about 1500.00 into it. I'd rather not spend money on another 2stroke if i dont have to. It just needs some cosmetics to be back to show room quality.Yes..i always had thought the only difference between varying HP models in the same block was just the carbs...but I have learned a lot in this forum. Emds is correct about the differences, so trying to get a few more HP out of a motor is really not worth it. Just sell your 90 and go buy a 115...should be able to do that cost neutral or close to it.
there is not any documented proof, that putting a 15 carb on a 9.9 will make the 9.9 a 15hp.
