littleflat10
- Dec 26, 2009
- 17
just bought a 14 grumman with a 25 hp johnson couple months ago . took it out a few times ran good . i took it out this fine morning and had alittle trouble starting figured i was cold . got about 200 yrds from launch and the motor killed . i turned around to see both terminals on battery smoking. tryied to disconnect but was to late it melted the ground off of the battery. so i paddled back a picked up drove home . 1 1/2 later i started tracing wires only to find the first connection into the motor was rubbing a small bracket wore a hole in insulation and was grounding out . so i took it apart and rerouted it . reconnected a differant battery and great no smoke. but now the motor wont start if i prime it ,it will run for a couple seconds then kill then it wont turn over agian. need help any ideas
