Badger2008
- Feb 4, 2008
- 76
I have a 40 HP Johnson Book says 1980
J40Eccs
G7723334
It has the wiring harness cut about 3 feet out of the outboard.
This wire harness attaches via a big red plug to another big red plug on the motor. I have an OMC key switch. What I want to do is make a test jack so I can test run the motor.
The wire harness coming out has the following 8 wires
Large Red/black stripe
yellow/ red stripe
Black/white stripe
purp/white stripe
Brown
Purple
Grey
Black
The key switch has terminals marked S, G, A, M, B (there is also a female bolt tap marked M as well)
All I want to do is make the motor run for test purposes.
can anyone tell me how to wire this test pigtail?
Thanks
J40Eccs
G7723334
yellow/ red stripe
Black/white stripe
purp/white stripe
Brown
Purple
Grey
Black
Thanks
