steering wheel adapter
doggypaddle
ok this is the first post ever ,i am trying to remove the steering wheel shaft adapter from an older searay 185. the steering wheel is a 3 spoke 16". that came with 1 snap ring and 3 screws. the adapter has a hex hole in it just bigger than a 9/16" bolt head . the bolt head is down inside this hole with no way to get a socket on it. how do you get this off? i found the answer from a local. the bolt is thru bolt and all i did was remove the nut underneath
