Re: trailer carpet
Never had to replace bunks/carpet (yet
), so this might be way off. But, if the existing bolts/nuts look pretty rusted, would it help to spray them good with WD40 and try to
break them loose before heading to the lake. In other words, get them to loosen while at home with more/better tools. Only problems I can think of are 1) breaking bolt 2) nut backing off on way to lake. Even if bolt did break off, you could put new bolt in for the ride to lake. Just trying to think of something to make work once at the lake easier. Also, might need a temporary jack stand under bunk while working at home.<br /><br />BL...
