drewmitch44
Thread starter- Joined
- Jun 26, 2005
- 1,749
http://forums.iboats.com/showthread.php?t=348930
Here is where I have left off. Let me give the skinny of what is going on. The car starts runs til warm then acts like its out of gas. I am able to get the car to run when I pull one of the fuel injector banks. Its a V6 so there is 2 fuses for the fuel injectors (bank1 and bank2) each control 3 injectors. I know that the car is running on 3 cylinders at this point. I can only pull one of the fusses and not the other. At first I thought it was a fuel restriction problem so I took it to a mechanic and he said that the fuel injectors were ether clogged or bad. Well now 6 new fuel injectors and it ran perfect for a day and then the same thing! I took it back to him and he said that he thought it was a bad catalytic converter because when i step on the gas when the problem happens the rpm's decelerate instead of accelerate. So I had the catalytic converter replaced at the local muffler shop and that did not help. So, I replaced the fuel pump even though I did not believe that the fuel pump was the problem since when you pulled bank 1 of the injectors the car would run but only on 3 cylinders. If you leave bank one and pull bank 2 the car would not run. So I think there is a problem with getting the bank one (3 injectors) to work. Im not sure at this point where to go. I have a service manual for the car but this problem is not in there.
I have checked the codes and Im getting a code 3-3 which indicates the MAP sensor. Im about to replace that today. Also I have been told that if the Crankshaft Position Sensor is bad that the ECM might not fire all the injectors. This sounds like a possibility of the problem that Im having.
Replaced at this point:
All 6 fuel injectors $500
Catalytic Converter $225
Fuel pump/strainer $100
Fuel Filter $80
Thinking about replacing:
MAP sensor (Manifold Absolute Pressure) $33
Crankshaft Position Sensor $20
Engine Control Computer!!!!!! $166 -core($90) =$76
Im at a loss and I really need this car to run. I have found that the speedometer is off. So that is another sensor. So Im thinking that maybee it is the ECU!!! If I am going 50MPH by gps the speedometer says that Im going 70 so that is 20 MPH off! So that is a lot of things that are wrong for a car that only has 53K miles. This car was owned by a older lady that did not drive the car verry much then sat for a long time. I picked it up because of the miles and not Im stuck! Thanks for any help anyone can give me!!!
Fuel Filter $80
