will a 1977 150 h.p. lower unit go on my 1974 115
dharne
and are there any modifications to make thanks for your help I have bought this lower unit and it appears that it will fit. I dont know much about these but i would assume i need to have th lower unit in the neutral position when i install it. But i have turn the spindle both ways as far as it goes and no matter where its at it seems to be staying in the same gear which i believe is forward. How do i get it in neutral? Also i changed the impeller as it has been sitting in a garage for 7 years. Is there anything else i should do before i put it on my motor?
Jeff_G
Re: will a 1977 150 h.p. lower unit go on my 1974 115
Yes and no
electricjohn
two questions and two answers.
daveswaves
Ensign
Yes and no
OK Jeff, now you have this merc head scratchin. What part is not compatible? Oh I know, depends on if it is a v6 or an inline? The inlines bolt up....I think. All mine are the other way, never had an actual inline 150 original lower end. Lots of others.
Zrt1200
I think what Jeff is try to say is.....
will a 1977 150 h.p. lower unit go on my 1974 115 (Yes)
and are there any modifications to make (NO)
daveswaves
Ensign
Yeah, I knew that....:redface:
Jeff_G
Geez usually I get canned for being long winded.
